Colchester Master Lathe 2500 wiring issues
Home Forums General Questions Colchester Master Lathe 2500 wiring issues
  • #635112
    Cara Shaw
      @carashaw80418
      Hi everyone,
      I wonder if you could help us, we have bought a colchester Master 2500 and we’re having quite a few issues getting it wired into 3 phase.
      The previous owner wired in a 3 pin 13 amp plug to the control gear, 0/220 and then ran the motor direct from a inverter transformer.
      I have a trans wave MT7 and would like to rectify the wiring to original but we are popping fuses. We are getting 3 phase power to the main isolator and from my understanding the bottle fuse coming from L1 through a 500 volt 2 amp bottle fuse should be the phase to power up the 240 control gear.
      Does anyone have any suggestions/ pictures of their bottle fuse wiring on this model?
      Cara Shaw
        @carashaw80418
        Help
        #635174
        Chris Pearson 1
          @chrispearson1
          You really ought to test properly rather than big bang testing. Have you a wiring diagram?
          #635176
          Cara Shaw
            @carashaw80418
            Yes we have a wiring diagram and the manual.
            And also we are testing it? Nothing we are doing is unsafe, just trying to see if anyone has any suggestions.
            #635188
            Chris Pearson 1
              @chrispearson1
              Well, if it passes the usual tests, it will not blow its fuses.
              It will be easier to consider the problem if you post the wiring diagram.
              #635193
              Jelly
                @jelly
                Is it possible that the clutch/brake assembly in the lathe is sticking after a long period of inactivity, which is causing the overload on startup?
                Had that issue with my lathe when it first came to me and some manual jiggling of the clutch plates combined with an oil change actually cured it.
                Not before I spent 6 hours painstakingly checking the wiring for a fault I was convinced had to be with the control gear mind you…
                #635199
                noel shelley
                  @noelshelley55608
                  Has the contactor got a 220v coil ? Noel.
                  #635204
                  Chris Crew
                    @chriscrew66644
                    I have a 1969 Colchester Student which has been run for the last 30 years from a 5HP Transwave static converter. I don't know if the wiring for a later Master will be different, I suspect it will be, but I am mentioning this because the power for the suds pump on my lathe was taken directly from the power input lines, not from the 'broken' side of the NVR. I had assumed that when the main motor was stopped, and the suds stopped flowing, that the suds pump had also been switched off. This was not the case and the output of the Transwave was still appearing at the pump motor which was obviously not powerful enough to trip out the starting capacitance of the converter and keep running. I think the pump motor just oscillated, all-but inaudibly, whilst getting hotter and hotter until over a period of time it burnt out at least one of the windings. This would not have happened had the lathe been running from a proper 3-phase supply but in the circumstances it cost me a suds pump motor rewind, so just check your wiring diagram in case the configuration presents the same issue I had.
                    My solution was to fit a small auxiliary NVR for the re-wound suds pump so that when the power was removed from the main motor the suds pump was similarly isolated although I suppose I could have just moved the factory wiring to the 'broken' side of the main NVR.
