AS DC31k says, the other gears will tell you what width it needs to be, and the bore and the size of any keyway.
If you measure the OD of a gear withb which the 56T has to mesh, and count the teeth, you will be able to calculate the Diametric Pitch
Knowing the dimensions of the central boss, and having calculated the O D from the 56T and the DP, you can make a gear, as long as you can find out the Pressure Angle.
With all this information, you can buy a gear cutter and, if you have a Dividing Head or a Rotary Table, make your own gear.
If you have not cut a gear before, buy Ivan Law's book "Gears and Gear Cutting"
There are probably websites for owners of lathes like yours (Do read what is on Lathes UK website about your lathe.. It may answer many of your questions.
HTH
