Posted by Andrew Johnston on 29/07/2012 11:46:01:
May be it was assumed that one wouldn't be screw cutting small diameter metric threads? How big is the lathe?
Big danger of going off-topic here
However, about the small threads you are possibly right. I can imagine that other (maybe even smaller) threads couldn be done with combinations not on the table.
This lathe is very small, comparable maybe to the Myford ML10. Up to now it has not received the honour of being shown on T. Griffith's pages (my fault, really, as I wanted to do this since years), I put a picture of the headstock in my album. The lathe has the quitr unique feature of a movable2-part bed. Normally, the centre height is 100 mm. By pulling the upper part out, you can obtain a large gap with centre height 200 mm (or a much longer bed length). It has also a very clever backgear, giving a very large speed range.
It is nor very rare in Switzerlans; I know of 2 others, one of them not far from my place.
Greetings, Hansrudolf
