Being as how the next clock needs a coil with a lot of turns on it I thought I would lash up a cnc coil winder, since I have a couple of spare steppers, a GRBL Arduino controller that can accommodate another driver, and a driver to fit on it. The idea is to use one stepper driving the bobbin and pretending to be say the X axis while the Y axis stepper drives an M6 leadscrew backwards and forwards. On the leadscrew an anti-backlash nut will drive a carriage with a guide for the wire. Just to keep myself motivated I thought I'd log the build as I go…
To attach the bobbin to the motor I will use a mandrel in an ER16 collet so I'll need a suitable chuck. I've got a full set of collets and various closers, so the options were either to butcher a chuck extension, which would be a shame and anyway they are made of tough and hard steel, or make one. I chose the latter just for fun…
Turned down a length of 1" FCMS to 22mm by CNC and threaded a 15mm length M22 x 1.5 using Mach 3 – yes it does do threading, I was quite pleased with this thread, made my own tool as well. Nut fits very smooth and shake free…
Next to bore out the taper.
8 degrees half-angle, 16mm dia at the mouth and 20mm deep. Body was drilled 10mm dia x 22mm first.
