Been asked to move the SX2P posts from the Warco WM thread to a new one so that it can be searched easily.
I will delete these posts from the old thread and replace them with a link to this one.
Any relevant threads from the Warco post on the SX2P will also be copied over but general replies will be left.
OK, could be long, go get a coffee.
First off as mentioned the base on the SX2P is the same as the X1L, sounds funny but the X1L has the longest travels of these small mill and is greater than the original X2 base which is the one fitted to Axminsters offering hence the small table size and bed travels.
Ballscrews won't fit straight in unless you go down to something like 10mm which as well as not being satisfactory they are very expensive.
The generic screws made in China at about 3 different factories [ all decent factories BTW ] fall into popular sizes and the 1605's are the most common and hence the cheapest.
The number is derived from 16mm diameter [ nominal as they are rolled ] and 5mm pitch.
So the screw for all intents and purposes is 16mm but the body of the ball nut is 28mm and the flange is 35mm but it's possible to cut some of the flange away with no detrimental results, so the secret is getting this 28mm diameter ball nut into spaces it wasn't designed for.
Now I hope you lot are dually grateful that I've knocked off early, forsaken my pie and a pint just to start a conversion I don't even need.
First the X axis as it's the first bit to hand.
There is enough room to get the screw in but not the barrel of the nut. Table is on the bottom and saddle is on the top.
However if we spin it over it has part of a groove already machined in.
Now if that groove is opened out all the way thru then the screw can lift up and allow the nut to clear the underside of the bed but still not get inside the saddle.
So.
Belt a pocket in with a 30mm inserted cutter to allow the nut to fit. Also mill one of the flats down on the ball nut to the hight of the 28mm part for clearance.
This gives us this.
Screw and nut fitted into the space with clearance and needs fastening to the saddle by the two top screws.
A new housing is needed for the end of the table to carry two angular contact bearings, oldham coupling and stepper mount in a nice block or casting.
Don't mount the stepper on 4 pillars, it's a machine tool not a bloody clock.
More to follow in a bit, got to feed the hound.
