I have been thinking for a while that most clock parts are less than 5mm thick and they are made of leaded brass so a small X-Y table with 100mm travel either way mounted on a small mill would machine most clock parts.
The program could stop to allow the manual lowering of the cutter (1.6 slot drill) than start again until the z depth needs to be altered.
Not complicated but I guess ball screws would be better and speed would not be an issue either but accuracy or at least repeatability as backlash would destroy the idea, is there a commercial table or plans for same that would fit the bill or even a full setup?
