I have now done a similar program to the general taper program above so that you can add an ER collet shape to whatever you are turning for fitting in a mill/lathe etc and be certain about it's concentricity. The collet shape could then be cut off when you are done with it.
The collet sizes are ER 11 to ER 50, and by means of text editing a .csv file, you can add your own. It comes with a 4 page PDF help file to show what the resultant shape will be like, the machining sequence and a toolpath plot for an ER25 collet for verification.
The principle limitation is that the toolpath does not include cutting the ER collet ejector ring groove, but it does add a comment specifying details of the groove. Comments can be turned off as the toolpath can easily get up to 300+ blocks depending on bar diameter and depth of cut. A relatively laborious, 5 stage cutting method has been used to maintain maximum bar stiffness for as long as possible.
The program is a 32 bit Windows program, definitely runs on Win 7, and probably any 32/64 bit windows compatible OS. It probably runs under WINE on Linux as the other programs do.
The link to the download is: **LINK**
Hope it's useful to someone. I will eventually add a page to my website for it, but haven't done so yet.
Richard.
