CNC dedicated mill or CNC converted mill?
Viewing 8 posts - 51 through 58 (of 58 total)
  • #485619
    Former Member
      @formermember32069
      geoff adams
        @geoffadams14047
        Barrie
        many a time i have sat with a cnc mill doing nothing costing i dont no what and production getting behind while QA drawing office and planning argue what is practical in the real world looked good on paper is the tolerance needed can it be achieved +- 002 from cast faces ok today you can probe it not in my day got fed up with all the crap and moved to Christchurch Dorset and went into building trade now retired
        back into engineering love it iam my own boss QA up to me
        Geoff
        #485637
        Duff Machinist
          @duffmachinist36701
          Posted by Emgee on 13/07/2020 23:04:13:
          Anyone had a Malware TROJAN Warning when using the Sieg CNC Catalogue thingy link an earlier reply ?
          Emgee
          Edited By Emgee on 13/07/2020 23:05:23
          Odd. I have the same Malwarebytes Premium (full), and it didn't crop up when I clicked on the website.
          #485640
          Duff Machinist
            @duffmachinist36701
            Posted by JasonB on 14/07/2020 07:16:41:
            One other thing to consider … …and the type of cut it is taking.
            Edited By JasonB on 14/07/2020 07:38:07
            Thanks Jason. Absolutely.
            Way back when I was young and beautiful, I had access to a Golmatic miller with DRO (£12k worth 20 years ago). The friend who owned it allowed me access to the machine on a regular basis. I was able to cut my teeth on it and spent a lot of time practising on scrap metal to get to know the machine, set-ups, etc. Unfortunately, the owner died 10 years ago and my milling days were abruptly ended (I couldn't afford the machine when it was put up for sale).
            Some of my 'hobby' projects back then included some complex cutting and I dearly wished for a CNC but back then, as you know, CNC was not as accurate as a manual machine (and still isn't, but to a lesser degree nowadays).
            I therefore have the basic milling skills and understanding that thing are far from simple. I'm going into CNC eyes wide open and not expecting simple (or cheap) solutions
            Thanks for the youtube link, I'll have a look. I've gone off gantry machines, but it's all good education regardless. face 1
            Duff.
            #485642
            Duff Machinist
              @duffmachinist36701
              Posted by Neil Lickfold on 14/07/2020 08:45:49:
              Making parts consistently to 10um is actually a tall order. Barrie is far from a beginner machinist and buying a machine and replicating what he has done is not an easy achievement. A Fanuc robodrill come to mind. **LINK** or the small Hass mills etc. But these are well over the hobby budget but are the lower end of dedicated mills. What you really want is a second hand DMG that is 10 years old or so. Is another option.
              There are many others. Some of the machines I saw a few years ago were not capable of making parts to 0.01mm .
              You will need to invest in good cutters and good holders. Currently the better ones are the holders that seat on the taper and the face of the spindle. The new series of hydraulic collets are actually out performing the shrink collet chucks.
              Agree. I don't know Barrie, but he comes over as someone who knows his stuff and is good at what he does (thanks Barrie!). teeth 2 I'm expecting a learning curve.
              I did look at DMG a little while ago, and checked for machines (and others) on the European trade sites. All the ones I could find (used) were too large and way too expensive. Quality holds its price (to a degree) I guess.
              I should also have said that the CNC mill would have to be benchtop size, although maybe my weight requirement of around 150-500 kg might have hinted at that.
              I'll have a look at the Fanuc and see if specs are within range. Thanks Neil.
              Duff.
              #485650
              Duff Machinist
                @duffmachinist36701
                Oops, sorry everyone. Hadn't realised there was another page of replies. I'll try and reply to all in one post.
                Posted by Andrew Evans on 14/07/2020 09:32:45:
                Is it a possibility to 'rough out' with a hobby CNC mill and then finish the crucial dimensions with say a surface grinder or in a manual way? Based on what others are saying it sounds like producing parts to that spec purely with a CNC mill might be beyond your budget
                Edited By Andrew Evans on 14/07/2020 09:41:12
                Thanks Andrew.
                Yes, I could rough out but I would need to make jigs, etc., and if I'm at that stage I would be in a position to finish the part off while still in the jig. In fact, all the work could be finished on a manual machine with DRO (as nearly all jobs can be), but it would be a really painful and long process. Having said that, I may have to go that route anyway.
                Posted by Baz on 14/07/2020 10:24:30:
                Why don’t you sub contract the work out to those with the 1/4 million pound machines and the small fortunes worth of tooling not forgetting the temperature controlled environment who can actually do the job, save you an awful lot of s**t, grief and aggravation.
                Baz – comes down to cost. There would be several parts that would need to go out. On top of that, I'm always worried that they won't do the job properly. I have rarely been satisfied with (non-machinery but nonetheless skilled) work delegated to someone else – they invariably screw up. Also, if I've made a mistake in my CAD file (cos' Sod's law), it'll cost me double. So yes… I'd feel really iffy about that but understand where you're coming from. High spec' mill ownership is not cheap.
                I would still need a mill of sorts so I'm not sure if I'll be saving any money anyway.
                Posted by Barrie Lever on 14/07/2020 12:49:14:
                No guarantee that they will do the job for any reasonable rate and might be more agro than doing it yourself.
                What the OP really needs is a prototyping setup like these guys produce
                B.
                Edited By Barrie Lever on 14/07/2020 12:59:40
                Thanks Barrie,
                Yes, no guarantee, and no guarantee that I've got the part right as these would be prototypes and prone to amendment. As a consequence, cost inreases.
                Thanks for the link. Hadn't looked at MDA and those are the machines that would fit the bill perfectly. The Q350 looks spot on. While it appears it's their 'entry level' (their Wabeco aside), no price is given but I'm guessing 15-20k. The other machines have as good or better specs but, of course, are appropriately priced.
                Interesting that they're synthetic granite (hmm, now there's a thought cool… ..I wonder if I could ma…)
                So far, the Wabeco range seems to be the best for the price. Yes, I would definitely be happy with a MDA machine but I'd need a wind fall. I'm discounting the Chinese mills as they seem to need refinishing to get any high accuracy result out of them, and to be honest, they're not far off the price of Euro/US made machines, after all is said and fixed.
                It may be that I'll have to make do with a manual Wabeco (or similar) and DRO fitted to do most of the work, converting to CNC as funds allow (although cost of the DRO puts the machine up in the CNC range). As said in an earlier post, all the work could be done on a manual mill but the agro involved in setting up might make me chuck the whole project in. I'll have a further think on this and look at what machining steps are practicable on an accurate manual mill with DRO to get what I need. If memory serves me, I (obviously) went through this assessment only to find myself saying "I need a CNC…".
                (The CNC would also make more sense if or when I went into small production mode, but that's way off in the future.)
                Thanks again everyone.
                Cheers,
                Duff
                PS. The CAD/CAM side of things is okay. While I have very little expereince of practical application, I've been able to play with a few programmes. Very daunting at first but I'm getting my head around this aspect. thumbs up
                #485656
                  Posted by Duff Machinist on 14/07/2020 20:10:24:
                  Have a look at what mine produced while still sat on the pallet and no cutter compensation, part I cut at the weekend had similar 0.01 deviation from drawn which is your 10microns. None of my 4 far eastern machines has been "refinished" or stripped and rebuilt.
                  DRO would only add £3-400
                  #485667
                  Duff Machinist
                    @duffmachinist36701
                    Posted by JasonB on 14/07/2020 20:48:58:
                    Well, that's me stood corrected!
                    Thanks Jason.
                    Duff.
