Thanks everyone for the big response – very, very much appreciated.
With your advice and observations, I'm now strongly persuaded to go down the dedicated CNC path. Tinkering is fun and educational (machinery allowing, which I clearly lack) but getting the jobs/projects done is more important for me. To clarify on some points brought up (which may now be moot)…
Yes, I will need precision as stated but the precision will vary. In many cases the tolerance will be +/- 0.03mm, with the 0.01mm precision less frequent but very much needed – it would be self-defeating to buy a machine that only does 95% of a job. However, I could mitigate against this by using two machines…
…the minimum size of table was given to incorporate the larger job sizes. Therefore, I'm basically asking a machine to do one and all jobs. In reflection, I could 'delegate' the jobs to two separate machines – a dedicated CNC to do the smaller, precision jobs, mostly aluminium, (about 90% of jobs) while the other can take on the larger jobs (about 10%). If I do this, I can reduce the working space of the CNC mill to about 150x140x40mm to incorporate all my needs. With this in mind, I'm also wondering if a CNC router (e.g., a Wegstr, etc.) might be good enough for those smaller aluminium jobs.
Having a look at my projects, the larger jobs can be done on a manual mill. It'll just take a lot longer, with a fair bit of fiddling and thinking outside the box but it can be done so perhaps I can consider this side of the issue to be solved. Also, the smaller projects are the more important so this can wait a while longer anyway.
Costing. Well, as little as possible of course.
At present, £3500 at the very outside. This may be broadened if I can sell a few things.
I shall look at the Denford Triac but with my revised requirements of the working space for a CNC as stated above, would a CNC router be a viable option? I'm thinking of one where the table moves and the gantry is fixed as these appear to be more stable but there's very little feedback on the interweb on the build quality and ability of these machines. Any thoughts? (I'm also conscious that I'm going off-topic on my own thread by asking about this!).
As an aside and certainly off-topic, I've heard that, given the right set-up, a CNC router (within the price range given above) can be used for cutting 41xx steel. I'm unconvinced of this but would be interested to know if I'm wrong.
Thanks again everyone.
Duff.
Edited By Duff Machinist on 13/07/2020 17:47:14
