On
20 October 2023 at 07:48 IanH said
<p style=”text-align: left;”>Apologies if this has been covered before but my iPad can not get past Cloudflare checking if the site connection is secure. I am connected now via my Android phone on our WiFi network so I suspect the problem is at the iPad end. It is an older iPad running 12.5.7 which is the best it can do. I can’t be the only one with this issue? Is there a fix?</p>
Ian
Ian,
Its not you or your ipad. It is more than likely to be Cloudflare.
As far as I am concerned, there are variable issues speed/login/change page error/delay, many of which I have experienced before with Cloudflare.
Until and unless the site developers see and realise this, they will keep going round and around in circles, thinking its their own fault, or the forum visitor who has an issue with their ip/service provider etc.
Cloudflare is robust and expensive, but if they are asked to provide an explanation, the responses will be less then helpful, and they will request more money for a plan upgrade. If and when Cloudflare is removed, hopefully a lot of the reported issues will start resolving themselves.
Ketan at ARC.
