Clockmakers Depthing Tool
Home Forums Clocks and Scientific Instruments Clockmakers Depthing Tool
Viewing 15 posts - 1 through 15 (of 15 total)
  • #3576
    David Carne
      @davidcarne27247
      David Carne
        @davidcarne27247
        I have a set of castings from Reeves I want to machine.
        Can anybody who has machined a set of these castings tell me the Model Engineer editions that covered the making of the depthing tool?
        I have a copy of Model Engineer 19 October 1973 but my article is incomplete on page 1016.
        I also have the Post Bag article of 17 January 1986 which mentions the dangers of boring the holes for the runners on the early castings (my castings are from 1980), can anybody comment on how they machined these holes?
        D V Carne
        #45880
        c
          @c
          You will also need page 1017 David; I can copy both these pages to your email address if you so wish.  The last paragraph of the article states that the author would be happy to oblige with castings via the Editor if required, but can find no editorial reference.
          Regards – Chris
          #45881
          David Clark 13
            @davidclark13
            Hi There
            Who is the author?
            regards David
            #45882
            c
              @c
              J.M.Wild
              #45884
              David Clark 13
                @davidclark13
                Hi There
                regards David
                #45917
                Ian S C
                  @iansc
                  MEW no 8 Dec 91 jan 92 has an artical A Clock Depthing Tool.Its a complete artical.Ian S C
                  #46600
                  john jennings 1
                    @johnjennings1
                    Wow is it that long ago that I wrote A Clock Depthing Tool  91/92!
                    It won’t help David Carne  as it is of fabricated construction.  (I couldn’t figure out how to drill/ream the parallel holes needed on a solid construction. )
                    It was made using a Unimat 3 and milling head and isl argely of aluminum alloy.
                    The use of alloy keeps the weight down considerably.
                    regards John
                    #798845
                    Chris Raynerd 2
                      @chrisraynerd2
                      Just to bring this back to the top, does anyone have:
                      Model Engineer 19 October 1973 Page 1016 and 1017 they can send me please?
                      I believe this is the Malcom Wild article which is the one I’m after.
                      Chris
                      #798847
                        It doesn’t get us much further, but
                        This appears to be the issue in question
                        https://digital.library.unt.edu/ark:/67531/metadc2332355/
                        … might trigger someone’s memory
                        Bob Murray
                          @bobmurray
                          Send me your email and I’ll send a pdf.
                          Bob
                          bobm4360@frontier.com
                          #798855
                            I’ve only just found this video:
                            https://youtu.be/ZIUwyqj74wM?feature=shared
                            JMW talking about his current offerings
                            Andrew Crow
                              @andrewcrow91475
                              Chris
                              Hi Chris, I have that magazine, the article actually runs on 4 different pages, if you still would like a copy I can scan it later and send it as attachments in a p m.
                              Andy
                              #798898
                              Chris Raynerd 2
                                @chrisraynerd2
                                Hi Andy
                                it would be much appreciated!
                                Chris
                                #799005
                                Matt Harrington
                                  @mattharrington87221
                                  Chris, I have the full scans of Issue 3475….
                                  Matt
