Hi,
What I want is a clock with a less ornate frame and larger gears. The clock uses a .8 Mod cutter for the going train. My most recent idea is to use the 1Mod cutter from the Wilding Brass Alarm Clock,so I don't have to buy another cutter, keep all the gear ratios and tooth counts the same and cut the gears with that . The PCD's would change and so would the OD's . The lantern pinions would be larger too.
All other things being equal, if that's possible, is a clock with larger Module gears as accurate as a clock with smaller M gears ? Does Module size affect accuracy ?
Thanks,
Mark
