My Contribution after taking on board all posts and further research. (Any comments welcome)
Climb Milling:
Downward force is exerted on work so can pull out an end mill out. Backlash is potentially added to depth of cut. This is especially important in lighter machines and those without back lash elimination. In more robust / rigid machines with heavy iron tables and tight gibs may not be an issue.
In lighter machines though the back lash if poor can be dangerous e.g. if milling at an intended .005 inch and the machine is poor with .020 backlash then you may get 0.025 cut which could break the machine. So depth of cut plus back lash is key.
Finally climb milling is reputed to give a better surface finish. However there are opposing arguments as always one being that tool deflection can introduce some surface imperfection.
Final advice from my findings is at least be aware of the dangers of climb milling, something I was totally ignorant of before asking on this forum.
Chris
