Clearing spark plug thread
Home Forums Related Hobbies including Vehicle Restoration Clearing spark plug thread
  • #508469
    AJW
      @ajw
      I'm working on an old Villiers engine which has been running with an incorrect spark plug, it was too short on reach.
      This has resulted in the threads getting carboned up and not accepting the correct longer threaded plug. I have turned up the old short plug to be used as a 'sort of' tap to clear the thread, and have applied plus gas in the hope that it will soften the deposit but wondered whether I might be better using something else?
      It's a big plug with an 18mm thread and didn't want to purchase a tap purely for just clearing the carbon!
      Alan
      AJW
        @ajw
        #508481
        Clive Brown 1
          @clivebrown1
          Would an 18mm plug thread chaser @ £6 from Machine Mart be within budget?
          Or a wire shaped like a hairpin with outwardly bent sharpened points and lots of patience.
          Edited By Clive Brown 1 on 19/11/2020 14:59:47
          #508491
          Speedy Builder5
            @speedybuilder5
            Use an old long reach spark plug and file the sparking end so that it "cuts" the thread clean.
            #508494
            Steviegtr
              @steviegtr
              I have a set of Dentists picks which are perfect for that type of job. Cheap ones on ebay can be got.
              Steve.
              #508496
              Dave Halford
                @davehalford22513
                Assuming the head isn't alloy, a Dremel size wire brush or a tube brush
                #508498
                old mart
                  @oldmart
                  Those dentists picks are very useful.
                  #508523
                  AJW
                    @ajw
                    Thanks guys, it is an alloy head (seems very soft!) I did start picking it out but thought there must be something to dissolve/loosen it.
                    I shall set to and get picking and use my modified plug!
                    Alan
                    #508617
                    John Olsen
                      @johnolsen79199
                      Well, don't use oven cleaner, which would dissolve the alloy.
                      I would try Speedybuilders idea.
                      Steviegtr
                        @steviegtr
                        Let us know how you go with it. I was an absolute Villiers nut when younger. 8E, 9E, 2T, 3T, 4T had them all. Used to tune the hell out of them.
                        Steve.
                        #508630
                        AJW
                          @ajw
                          Must admit if was going to try anything it could be citric acid? No science behind that just wondering!
                          This Villiers engine is not from a motorcycle it's a model 25HS direct coupled to a 2kw generator, dates from 1964. It has been rebored but looks like it's not done much running since as the bores hone marks are clearly visible.
                          I'm enjoying the project, nicely made engine.
                          Alan
                          #508631
                          Ian Hewson
                            @ianhewson99641
                            I used an old spark plug that I cut a spiral groove down the thread with an hacksaw when I needed to clean out spark plug threads. That worked well for me.
                            Ian
                            #508637
                            Ady1
                              @ady1
                              cut an old spark plug in half? or just less than half, with an angle grinder, at the leading threads part, so they are square on and full size instead of tapering
                              then screw it in to gouge the garbage straight out of the thread kinda thing
                              Edited By Ady1 on 20/11/2020 02:54:36
                              #508649
                              Maurice Taylor
                                @mauricetaylor82093
                                Hi ,What’s the point of trying all these things ,when the proper tool is £6 at Machine Mart.If you damage it ,a helicoil kit will cost a lot more also a lot more time than the 2minutes this tool will take. I have one of these .
                                Maurice
                                #508651
                                J Hancock
                                  @jhancock95746
                                  Ahh, we're back to that definition of a 'engineer'.
                                  Anyone can do it for £6 , an 'engineer ' can do it for nothing.
                                  #508719
                                  martin perman 1
                                    @martinperman1
                                    Posted by Clive Brown 1 on 19/11/2020 14:59:31:
                                    I'm an engineer smiley but still bought the above which has worked for me for many years on my Stationary Engines and it has a 14mm plug thread on the other end. An engineer cannot do it for nothing, cost of correct material, electricity and time all adds up wink
                                    Martin P
                                    #508720
                                    martin perman 1
                                      @martinperman1
                                      Tilt
                                      Edited By martin perman on 20/11/2020 13:32:17
                                      #508725
                                      AJW
                                        @ajw
                                        Success! I had the old short reach plug on which I turned the body down to less than the thread root diameter, where upon it fell apart!
                                        But no problem, I ground a cutting edge on the end and used one of those 'easy out' screw removers to drive it into the thread, picked out what I could with a dental type device and eventually managed to work the short stub through the head casting.
                                        All because someone had fitted the wrong plug, but got there in the end.
                                        Alan
                                        #512061
                                        martin haysom
                                          @martinhaysom48469
                                          i got one of these engines [ attached to a landmaster mk 1 ] i seam to remember it had a short reach spark. could be wrong it was repaired years ago by fitting a brass plug
                                          #512063
                                          Mick B1
                                            @mickb1
                                            Stick the new long reach plug in the lathe and turn away the thread that would foul the fouling. If the short reach plug had enough thread to avoid blowing out, so would the longreach with a shortened thread.
                                            laugh
                                            Ah, you sorted it already…wink
                                            #512075
                                            Hopper
                                              @hopper
                                              The way that motorcycle mechanics worldwide have been doing this for the past 120 years or so is to take a sparkplug and put a small hacksaw cut lengthwise through the end of the threaded section. Screw it down the hole and it makes a good enough tap to clean up aluminium threads and remove carbon.
                                              #512776
                                              Adrian Smith 6
                                                @adriansmith6
                                                Hey Alan,
                                                how is it looking right now, I would be pretty happy if you send a pic of it, when you are finished with it wink.
                                                Regards Adrian
