Clearance for piston and cylinder end cap
Home Forums Locomotives Clearance for piston and cylinder end cap
  • #1107
    william Powell
      @williampowell50917
      william Powell
        @williampowell50917
        Hello
        I have been looking for a guide or fomula to calculate the clearance between the piston and the cylinder end caps. I have had no luck in a internet search. The cylinders in question are form the Stuart Turner Victoria 1" bore x 2" stroke, but being using in a vertical boiler steam loco.
        Any ideas where i might find the imformation?
        Thanks
        William
        #90832
        David Clark 13
          @davidclark13
          Hi There
          You don't need a formula.
          Length of cylinder – depth of recess on both cylinder covers – thickness of piston.
          Divide by two and that is the clearance to leave at each end.
          Assuming you have the drawings.
          regards David
        Home Forums Locomotives Topics
