Cleaning up after Silver soldering (brazing)
Home Forums Beginners questions Cleaning up after Silver soldering (brazing)
Viewing 9 posts - 26 through 34 (of 34 total)
  • #60767
    Sam Stones
      @samstones42903
      Hi Nick,
      Apologies to Clive also!
      I know this is something of a digression from Silver Soldering, but . . .
      On his marriage certificate c1910, my grandfather’s occupation indicates that he was an Agricultural Engineer. I have admired this detail since I seem to have followed suit.
      However, in those days, would an agricultural engineer be more of a blacksmith?
      Regards to all,
      Sam
      Nicholas Farr
        @nicholasfarr14254
        Hi Sam, yes I agree a little OT, but agricultural engineers were/are blacksmiths, which was one of the main source of work where I first started. Some blacksmiths also shod hoarses, which of course is part of a farrier’s job. A farrier may not have made hoarse shoes though, but a blacksmith would, but the blacksmith wasn’t always a farrier.
         However both agricultural engineers/blacksmiths basic material is black iron/steel. Modern agricultural engineers are involved in a lot more technolegy, and probaly steer away from the blacksmith tag. The machines your granfather worked on were most likely hoarse drawn and low tech compaired with todays machines.
        Regards Nick.
        Edited By Nicholas Farr on 19/12/2010 00:23:53
        #60775
        Sam Stones
          @samstones42903
          Nick,
          Now you’ve got me thinking. My grandfather married into a family of  Cab Proprietors, but this is now getting too far from Silver Soldering.
          Perhaps we should continue this on a private basis?
          Sam
          #60781
          Ian S C
            @iansc
            A Farrier also dressed the horses teeth, well i supose it was similar to fileing the horses hooves. Each in there age were the “hight Tech” engineers of there time, and worth following.  Ian S C
            #60792
            Michael Cox 1
              @michaelcox1
              You can buy spirits of salt (hydrochloric acid) from Toolstation (http://www.toolstation.com). This is a very effective pickle for copper and steel when diluted 1 part spirits of salt to 5-10 parts water. Make sure you keep it in a well stoppered bottle since the fumes promote rapid rusting af any steel around.
              #60793
              Sub Mandrel
                @submandrel
                Any ideas what sort of woork it would be in the RAF? Beating up intake manifolds?
                Ian S C
                  @iansc
                  Perhaps wave guides, and other bits for radar, and other radio and electronic gear.  Ian S C
                  #60808
                  Michael Kilpatrick 1
                    @michaelkilpatrick1
                    @Stub Mandrel
                    Shipyard Coppersmithing consisted mainly of pipe manufacture(Copper-CuNi)
                    With some rather substantial thick walled (CuNi) pipe used on Hydraulic & High Pressure Air Systems.
                    Connection of this pipework was facilitated with a Phosphor Bronze Fitting containing an “O” Seal grove. These fitting were Silver Soldered to the pipe.
                    This process has now given way to welding pipes in situ.
                    #60817
                    Sub Mandrel
                      @submandrel
                      A bit early for that. I saw a photo of him in the Sudan or Egypt with a big biplane airliner (either Hengist or Horsa) in the background.
                      My other grandfather worked on such things, and sonar, in all three services!
