Posted by Bazyle on 06/04/2023 10:50:47:
Don't use the chemical first as it will leave converted rust stuck on. First use brass wire brush, then scotchbrite, then phosphoric acid (no point in paying for special brands) followed by the scotchbrite again to remove the converted rust.
I like phosphoric acid as a rust remover, but it is fundamentally different to evaporust which is non-corrosive to steel/iron but breaks down rust via a redox reaction.
It's some very clever chemistry which being proprietary isn't well characterised, although I have a couple of theories about how they've accomplished it after playing about with trying to formulate something which would do the same thing, albeit with not as much success as the evaporust developer (removing rust is easy, the not corroding iron in an aqueous media no matter how long it's left is hard).
