Cleaning ER collets
Cleaning ER collets
Home Forums Workshop Techniques Cleaning ER collets
  • #78605
    Douglas Johnston
      @douglasjohnston98463
      Does anybody have an easy way of cleaning out the debris from ER collets. A toothbrush can get to most of the slots but the bore seems to be rather tricky. Cotton buds tend to get caught up on the sharp internal edges of the slots, leaving strands of cotton inside. Has anyone got a (cheap) solution?
      Douglas Johnston
        #78607
          You can buy a set of small brass wire “bottle brushed” for cleaning the collets used on woodworking routers which will do the job. Trend make them.
          J
          #78608
          Donhe7
            @donhe7
            Speaking as one unfamiliar with ER collets, may I suggest pipe cleaners as a possible solution to the problem
            donhe7
            #78610
            magpie
              @magpie
              Chronos do a large set of round brushes. Various sizes in soft bristle, brass wire, and steel wire. The set also has a handle and an extension to reach down boiler tubes. I bought a set at the Harrogate show last May, and have found them very usefull.
              Derek
              #78611
              RJW
                @rjw
                You could always try Gun brushes, supplied in various sizes and used for cleaning gun barrels!
                I used them all the time for cleaning out oilway drillings in crankshafts, picked them up for not a lot of money from a local gunsmiths shop.
                J.
                Edited By RJW on 26/11/2011 10:42:02
                #78613
                John Stevenson 1
                  @johnstevenson1
                  Is this for cleaning or polishing to put on the mantlepiece ?
                  Been using ER’s since they first came out, a swipe thru the slots with a 6″ rule or bit of steel banding and a quick blow down the bore and jobs a good un.
                  Does pay to drop them on the demagnetiser from time to time.
                  John S.
                  #78615
                  Dave Martin
                    @davemartin29320
                    If there’s “gunge” in there, try dropping them in an ultrasonic cleaner (just make sure to dry them out properly afterwards though, possibly in the bottom oven on a low heat!)
                    #78623
                    Chris Trice
                      @christrice43267
                      Soft paint brush in a pot of white spirit works wonders.
                      #78626
                      Douglas Johnston
                        Thanks for the replies, some excellent ideas for cleaning the collets. I like the idea of the brass bottle or test tube type cleaners so I must get some if I can find a source that does not charge an arm and a leg for postage.
                        I need to go now as I have to polish the lathe before puting it on the mantlepiece.
                        #78637
                        Sub Mandrel
                          @submandrel
                          I’m the untidiest worker in the world and I don’t seem to get swarf inside my ER collets. What have you been doing with them, Douglas?
                          Gone Away
                            @goneaway
                            Always check “brass” brushes with a magnet.
                            #78655
                            blowlamp
                              @blowlamp
                              Like John, I give mine a quick blast of air down the bore whilst I block the other end to ensure the air has to exit through the slots.
                              Martin.
                              #78658
                              Jens Eirik Skogstad 1
                                @jenseirikskogstad1
                                I has ER 32 collets, the collets is cleaned free for chips with air blast. In case dirty by oil/cutting fluid: use white spirit + air blast (do not use indoor due fog of white spirit).
