They are made using a very specialized type of material, it's designed to suffer as little expansion/contraction as possible under temperature extremes.
Your point is? Or was that just a passing 'aside'
Makes no difference to the method of scratch removal. Needing to remove the scratches, not polish them, may be important.
Cloudiness may have a different connotation.
From the net:
Today, the canopy is a multi-layer structure. In case of the F-16, it consists of three layers:
The innermost layer is 0.5 inch thick polycarbonate and drape-molded into the compound curvature shape.The center layer is 0.05 inch polyurethane to bond the inner to the outer layer.The outer layer is a 0.125 inch layer of acrylic (PMMA).
So not really any different on the surface, which is where it will get scratched/abraded? Poly methyl methacrylate – perspex to many.
Edited By not done it yet on 22/05/2017 11:51:34
