I have an aluminium casting which sits in saltwater as part of a beaching leg. It is only occasionally used but has suffered from corrosion under the painted finish.
Before I can use a primer and topcoat paint system I need to clean off the white powdery corrosion products. Some parts of the casting are difficult to get to with a rotary wire brush and ideally I would like to chemically remove the corrosion products rather than have them blasted.
Has anyone any experience of doing this?
Many thanks in advance.
