Clarkson Tool Grinder Related: contd.
9. Tooth rest for spiral work 91103 with rotatable tooth mounting.
10. Tooth rest for general work 97010.
11. Adapter bush set metric 92617 – 92622 inc., OD 25mm x IDs 6, 8, 10, 12, 16, 20mm.
12. Adapter bush set inch 92607 – 92611 inc., OD 1in x IDs 0.25, 0.375, 0.5, 0.625, 0.75in.
13. Wheel flanges, small 92559(?) (on machine), large 93575(?) In pic – latter somewhat rust pitted and possibly of local mfg.
14. Extension spindle 92614(?), OD 1.5in.
15. Miscellaneous loose teeth.
16. Set of unidentified (possibly local mfg) ground cylindrical metric mandrels, OD 10, 11, 12, 14, 14.42 (long), 16, 18, 20, 25, 30mm.
17. Regrind mandrel, unidentified but probably OEM, 1.25 in dia spigot. Dark staining is surface.
Edited By Sawdust on 09/05/2021 15:44:00
