Clarkson Schools class loco re-designed for piston valves.
I am building one of these in 31/2 gauge. I have made the cylinders and piston valves. The original was slide valve. It was designed by Jackson in 1934. I am struggling with adapting the valve gear. I’ve looked at the simulators available but I can’t see how to use them. Does anyone please know which is the easiest to use? I made the piston valves with the same port widths and lap as the slide valves thinking it would just be a case of swopping the connections on the link between the valve rod and the expansion link but i think there is more to it than that now I have read Don Ashton’s website about Walschearts gear. Has anyone adapted a slide valve design to piston valve?
