Poly V belt may be too effective at power transmission for safety on a T&C grinder like the Clarkson with relatively exposed wheels in close proximity to the operator. Make that very exposed for the earlier examples of the breed!
It is said that power transmission should be only just sufficient to spin the grinding wheel and do the job. Hence the belt will slip should a jam up occur or a chunk of wheel escape. A more positive drive may lead to wheel burst or similar undesirable outcomes under such circumstances.
I have a translucent yellow plastic flat one on mine with visible re-enforcement threads. It works.
The four short bar motor mount system is a royal pain to set so to simultaneously achieve correct tension and alignment so the belt stays on the pulley. I modified mine with L shaped brackets replacing the lower short arms. Much more civilised. Drawings and pictures somewhere if of interest.
