Where I worked back in the 1960s dedlock cutters on 40 int holders were used on iron castings,it was company practice to grind the 90degree point where the cutting edges met ,back at 45 degrees with a small cutting face width of about 3/16 so there was no sharp point to get chipped ,this practice improved cutter life and finish , I always found the dedlock cutters to be very good and rigid enough to prevent any chatter and of course with ths Clarkson system these threaded cutters were easy to remove.
