Clarke cl500m mill head bearings
  • #581960
    Stuart Cox 3
      @stuartcox3
      Hi all
      Does anyone know how to lubricate the bearings in the mill head of the Clarke CL500M?
      Many thanks
      Stu
      Stuart Cox 3
        @stuartcox3
        Anyone know to lubricate them?
        #582157
        old mart
          @oldmart
          If the bearings are taper roller, I would recommend a high melting point lithium grease, as used for older car wheel bearings. Be sure to leave at least 50% air space when packing them.
          #582175
          Stuart Cox 3
            @stuartcox3
            Thanks, I'm not sure if they are tapered bearings as I haven't taken it apart yet. I was hoping someone who has managed to do this could advise?……
            #582181
            old mart
              @oldmart
              I found the parts list, they are very likely taper roller, but that grease would work with any ball or roller bearings. Why do you want to replace them?
              #582185
              Stuart Cox 3
                @stuartcox3
                Thanks, I don't want to replace them, I just want to know how you get to them to lubricate them. I'm presuming I don't have to strip the mill head apart every time they need lubricating….
                #582186
                Stuart Cox 3
                  @stuartcox3
                  …or maybe I do?
                  #582193
                    Can anyone confirm the bearings need maintenance? I've an idea they're sealed for life and are replaced if they clap out.
                    old mart
                      @oldmart
                      I agree with SOD here, they are probably not intended to be lubricated during their lifespan. The manual should show lubrication points and there may not be any mentioned for the lathe spindle either.
                      #582197
                      Stuart Cox 3
                        @stuartcox3
                        All it says in the manual is .. 'Lead screw and mill head spindle should be oiled weekly '…. so maybe you're right. The bearings are a little noisy so looks I may have to replace them then.
                        Thanks Stu
                        #582203
                        old mart
                          @oldmart
                          Strange, I downloaded the CL500M manual from the Clarke website, and the routine lubrication on page 23 does not show any lubrication of the milling spindle.
                          #582205
                          Stuart Cox 3
                            @stuartcox3
                            ..page 23 under the heading Weekly
                            #582208
                            Stuart Cox 3
                              @stuartcox3
                              ..although there's no diagram or reference though show how to oil the mill head spindle
                              #582211
                              old mart
                                @oldmart
                                I can see the oiling of the quill lever spindle, that is all there is on the mill .
