Clarke CL500M longitudinal feed screw
Home Forums General Questions Clarke CL500M longitudinal feed screw
Viewing 25 posts - 1 through 25 (of 48 total)
  • #517206
    Stuart Cox 3
      @stuartcox3
      Does anyone know if the nut on the longitudinal feed screw is adjustable and if so is it supposed to look like this? I'm wondering if there is supposed to be a bolt and it has sheared off. I tried a few different allen keys in the hole to see if there is an allen screw in there but doesn't seem to be?
      Thanks Stuart
      Stuart Cox 3
        @stuartcox3
        #517207
        Steviegtr
          @steviegtr
          Yes that type of nut with the slot is to take out thread play. lash. By nipping the bolt it squeezes the leadscrew & removes the play. Unless i am wrong.!!!
          Steve.
          Edited By Steviegtr on 03/01/2021 14:16:15
          #517210
          Stuart Cox 3
            @stuartcox3
            Posted by Steviegtr on 03/01/2021 14:15:32:
            Steve.
            Thats what I figured Steve, but I can't see how I can squeeze the two halves together without a nut head or alllen screw head?
            #517216
            Steviegtr
              @steviegtr
              I have only seen them & not adjusted one. So do you have a grub screw that pushes the gap apart or a bolt that pulls them together. Sure some one will be along shortly that has done this.
              Steve.
              #517218
              Steviegtr
                @steviegtr
                Have you had a look at these drawings.
                Clarke lathe PDF
                Steve.
                #517220
                Stuart Cox 3
                  @stuartcox3
                  Posted by Steviegtr on 03/01/2021 14:38:00:
                  Clarke lathe PDF
                  Steve.
                  Thanks, yes I have, but there is no mention of an adjusting screw, just part no 54 which is the complete feed nut 🤔
                  #517258
                  Dave Halford
                    @davehalford22513
                    So assuming you've found an allen key goes right through, what stops you buying a screw pack from B&Q and fitting it?
                    Whatever size fits. just be gentle with it, you need some lash or the thread locks.
                    #517261
                    john halfpenny
                      @johnhalfpenny52803
                      There should be a screw to open out the slot and take up most of the backlash. It's in the other end of the photo – unless it's missing
                      #517265
                      Stuart Cox 3
                        @stuartcox3
                        Thanks Dave, thanks John.
                        I have just been digging around and found a load of crud covering an allen bolt head the other side of the nut. It was solid crud, almost like body filler and flush with the surface of the nut, so it completely camouflaged the bolt head. Anyway I have dug it all out and managed to tighten the bolt and take out quite a bit of back lash.
                        I don't think it has ever been adjusted. I didn't over tighten the bolt and made sure the threads still run freely.
                        Problem sorted!
                        Thanks Stuart
                        #517266
                        Robert Butler
                          @robertbutler92161
                          I have absolutely no experience of these machines but understand the principle of the backlash adjustment. I would have thought any adjustment screw would be fitted from the exposed end shown in the image as the extra thickness provides more support to the adjusting screw. The narrower (thinner section) is also more likely to be deflected to achieve the adjustment required. Is the screw missing, or if of allen screw configuration is it just that the hex is smaller/larger than anticipated – or even a slot head screw?
                          Robert Butler
                          Edited By Robert Butler on 03/01/2021 17:32:56
                          #517267
                          Stuart Cox 3
                            @stuartcox3
                            Posted by Robert Butler on 03/01/2021 17:30:54:
                            Robert Butler
                            Thanks Robert. See above
                            #517298
                            john halfpenny
                              @johnhalfpenny52803
                              Stuart, these lathes were typically bought by the unknowing – never adjusted before purchase, and never set up after purchase, so they have a reputation of being sloppy and poorly made. You will find however that with proper adjustment, and there are many adjustment features, your lathe will likely work well and accurately.
                              #517444
                              Howard Lewis
                                @howardlewis46836
                                Our forebears produced splendid work on machines lacking even the features of the CL500M.
                                A skilled man can produce good work on a poor machine. An unskilled one can produce poor work on a good machine. I bear witness to that!
                                Many a good tune and all that.
                                Once it is sorted and you are familiar with the machine you will be surprised what you can do with it.. You just have to recognise the limitations and work within them. Add few "bespoke" accessories and even more will be possible.
                                Saddle Stop and Centre Height Gauge spring to mind as being useful in the very near future.. Then Tailstock Die, and Tailstock Tap holders, even Floating Reamer Holders, and a Tailstock Drilling pad could be added to the list..
                                The Milling facility would allow you to make your own Tangential Turning Tool holders.
                                The world is about to become your oyster!
                                #517447
                                Pete.
                                  @pete-2
                                  They appear to have a substantial compound slide, which is one area that seems to be lacking in many smaller far eastern machines.
                                  #517462
                                  martin perman 1
                                    @martinperman1
                                    Stuart,
                                    The cross slide uses the same adjustment, I regularly squirt oil along the leadscrew, do you have two metal gaurds fitted to the traverse casting covering the leadscrew these keep most of the muck off the thread.
                                    I've just noticed you asked for the name of my VFD, I will pm the details.
                                    Martin P
                                    #517464
                                    martin perman 1
                                      @martinperman1
                                      Oops
                                      Edited By martin perman on 04/01/2021 18:03:41
                                      #517466
                                      Stuart Cox 3
                                        @stuartcox3
                                        Posted by Howard Lewis on 04/01/2021 16:53:36:
                                        Thanks for the encouragement Howard
                                        #517467
                                        Stuart Cox 3
                                          @stuartcox3
                                          Posted by martin perman on 04/01/2021 18:01:56:
                                          Stuart,
                                          Martin P
                                          Do you mean the telescopic looking metal guards Martin? I don't have any covering on the lead screw at the moment but have considered adding something
                                          #517480
                                          martin perman 1
                                            @martinperman1
                                            Stuart,
                                            The ones fitted to my lathe are mounted above the lead screw and are attached to the traverse casting either side and are held in place by one screw each, they are a length of metal sheet about 5" long covering the leadscrew, they are not shown on the drawings, something else for me to remember I will photograph them on Thursday and PM you them, part time job and other duties dont allow sooner smiley
                                            Martin P
                                            #517485
                                            Stuart Cox 3
                                              @stuartcox3
                                              Posted by martin perman on 04/01/2021 18:50:50:
                                              Stuart,
                                              Martin P
                                              Thanks Martin, much appreciated
                                              #517506
                                              john halfpenny
                                                @johnhalfpenny52803
                                                Google images has plenty of shots of the standard bent tin guard – which can easily be extended or given a telescopic section. The standard length guard works quite well.
                                                #518759
                                                martin perman 1
                                                  @martinperman1
                                                  Stuart,
                                                  As promised pictures of the guard for the lead screw, very basic but it does the job.
                                                  Hope this helps,
                                                  Martin P
                                                  #518766
                                                  Stuart Cox 3
                                                    @stuartcox3
                                                    Posted by martin perman on 09/01/2021 20:43:26:
                                                    Stuart,
                                                    Hope this helps,
                                                    Martin P
                                                    Thanks Martin…… just trying to figure out what you've done?
                                                    #518767
                                                    martin perman 1
                                                      @martinperman1
                                                      How do you mean, this is the underside of the traverse lead screw, showing the guard from both sides of the traverse which also shows how its mounted.
                                                      Martin P
