Posted by thomas ryckmans on 07/04/2023 11:12:04:
Hi everyone,
I need to change the timing pulley of my CL300M lathe, the spare part I received from ARC (C3-148 Motor Timing Pulley) has an internal diameter of 8.85mm but the axis of the motor has a diameter of 7.91 mm, so of course the pulley moves around. Are there several models of these lathe, where the axis diameter has been changed? Any help much appreciated! As I don't live in the UK anymore, I can't just bring the lathe to a shop ![](data:image/gif;base64,R0lGODlhAQABAAAAACH5BAEKAAEALAAAAAABAAEAAAICTAEAOw==)
many thanks!
Thomas
Hello Thomas,
Do you really have a Clarke CL300M, or is it some other make?
If you have a Clarke CL300M, then you have ordered the wrong spare.
A Clarke CL300M is a C2 – brushed motor base model mini-lathe.
A C3 mini-lathe looks different from a C2 / CL300M mini-lathe.
You have ordered and received Spare part C3-148 – which has a nominal bore 9.0mm as specified in the details on this page link
You should have ordered C2-148 – which has a nominal bore 8.0mm as specified in the details on this page link
- A C2 mini-lathe is the same as a Clarke CL300M, and to the best of my knowledge, made by SIEG.
- A C2 brushed motor is smaller in frame size than a C3 brushed motor, made by SIEG.
For further clarification, C2 and C3 and CL300M are brushed motor minilathes made by SIEG.
The above models are different from SC2 and SC3 which are brushless motor minilathes made by SIEG.
Minilathes from Axminster, ARC, Clarke, Zoro/Cromwell – Osaki, to the best of my knowledge are made by SIEG.
When buying spares, it is best to be sure about which SIEG machine you… i.e. specifically SIEG C2, C3, SC2, SC3.
Hope above informarion helps.
Ketan at ARC.
