Hello all I have a Clarke CL300M mini lathe and recently the forward/off/reverse switch internals fell apart and as a result it blew the mains fuse and tripped the house mains control panel. I ordered up a replacement and installed it but now when I attempt to start the lathe the internal fuse keeps blowing. I have confirmed the motor is ok and replaced the fuse holder but to no avail. I think the dramatic failure of the f/o/r switch has damaged the circuit board (FC250J/230V variant) can anyone recommend a replacement controller, thanks.
