Clarke Cl300m lathe
Clarke Cl300m lathe
Home Forums Help and Assistance! (Offered or Wanted) Clarke Cl300m lathe
  • #480060
    Ross Bruce
      @rossbruce23155
      Hi, I was recently given the above lathe but it’s missing a gear that puts the lead screw into either forward or reverse, there should be two gears but I’m missing the larger one, I’ve looked on the Clarke website but cannot find it? Any ideas?
      Thanks Ross
      Ross Bruce
        @rossbruce23155
        Missing gear
        #480066
        Nick Clarke 3
          @nickclarke3
          The lathe manual is here **LINK**
          If you have a look at the exploded diagram I think it is part 39 – pinion 25T
          Clarke's spares dept is on 0871 410 1270
          Edited By Nick Clarke 3 on 15/06/2020 20:59:51
          #480074
          Ross Bruce
            @rossbruce23155
            Posted by Nick Clarke 3 on 15/06/2020 20:43:30:
            Yeah think your right! Thanks for that, il give them a ring tomorrow, cheers Nick
            #480144
            Howard Lewis
              @howardlewis46836
              The lathe is most probably made by Sieg.
              If so, talk to Ketan at Arc Euro, about the Tumbler Reverse..
              If they do not have stock, am sure that they will try to source the parts for you.
              HTH
              #480195
              Ketan Swali
                @ketanswali79440
                Hi Ross,
                It is a SIEG C2 lathe, spare parts for which can be found on this page.
                Ketan at ARC.
                #480338
                Ross Bruce
                  @rossbruce23155
                  Posted by Ketan Swali on 16/06/2020 11:18:08:
                  Hi Ross,
                  Ketan at ARC.
                  Cheers Ketan, just ordered part needed, thanks for your help
                  Ross
                  #621958
                  John Rudd
                    @johnrudd16576
                    Wrong window….
                    Edited By John Rudd on 20/11/2022 20:04:12
