Clark Lathe Problem
Clark Lathe Problem
Home Forums Workshop Tools and Tooling Clark Lathe Problem
  • #74659
    Trevor Wells
      @trevorwells94316
      Hi
      I would appreciate some help with a problem with my clark 300m lathe,
      When I started to turn a piece of metal this evening at quite a low speed
      a rumbling sound came from the chuck area and the chuck almost stalled
      setting the lathe at a very slow speed I was able to hold the stock bar in the chuck and stop the chuck moving but there was still a rattling noise coming from the headstock as if a gear or belt was slipping.. Before I have to strip the headstock
      I was wondering if anyone had any ideas what this might be.
      Thanks in anticipation.
      Trevor.
      Trevor Wells
        @trevorwells94316
        #74661
        Pat Bravery
          @patbravery
          I have had the same, in my case the belt stripped it’s teeth, I changed the sprocket and belt, fairly easy job. Best regards Pat
          #74663
          Trevor Wells
            @trevorwells94316
            Thanks for that Pat ,Was that on a clark lathe too ?
            #74665
            Pat Bravery
              @patbravery
              Yes the CL300, I get spares from Clarke or Machinemart and find them reasonable, best regards Pat
              #74666
              Trevor Wells
                @trevorwells94316
                Thanks a lot
                #74706
                Trevor Wells
                  @trevorwells94316
                  Checked the lathe tonight and thankfully it was just a loose drive belt, Re-tensioned
                  and now working fine..
                  #74975
                  Sub Mandrel
                    @submandrel
                    It’s worth taking the time to check the belt isn’t rubbing, there are various screws that adjust the angle of the motor as well as the tension. A related problem I had was the plastic key in the middle of the toothed pulley stripped. I hand filed a groove to replace it and fitted a metal key.
                    Trevor Wells
                      @trevorwells94316
                      I did check to make sure it wasnt rubbing but the motor does seem to be angled downward at the pulley end .
