Clark chuck dismantling
Home Forums Manual machine tools Clark chuck dismantling
  • #566090
    sparky mike
      @sparkymike
      I need to take my Boxford three jaw Taylor (not Clark!! ) chuck to bits as it is getting stiff to opeate. There are two socket head screws in the rear. What do they do ?
      I have removed jaws. Does the centre push out or screw out to the rear so that the scroll can be removed ?
      Mike.
      Edited By sparky mike on 08/10/2021 13:19:01
      sparky mike
        @sparkymike
        #566116
        sparky mike
          @sparkymike
          Panic over. I tapped the chuck gently with a hide mallet, after removing the two sunken screws and the back end of the chuck came off. There is a split dead centre of the chuck key square hole rotators.
          Cleaned it all out , and there was a lot of bits of brass etc. in various places, but after putting back together it is still a bit on the stiff side. ??
          Mike.
          #566125
          old mart
            @oldmart
            There are two possibilities for the stiffness, there might be some muck in a difficult to detect place, or maybe the chuck is in an unworn condition and the parts are close fitting. You did oil all the moving parts, I trust.
            #566130
            sparky mike
              @sparkymike
              It had the remains of grease in it ,which I replaced.
              It is stiff without the chuck jaws fitted.. There is a thrust washer that sits next to the scroll. I did wonder if that was a fraction too thick, but decided to leave that alone until I gather more info.
