Citric acid cleaning of mild steel prior to and post silver soldering
Home Forums Help and Assistance! (Offered or Wanted) Citric acid cleaning of mild steel prior to and post silver soldering
Viewing 2 posts - 1 through 2 (of 2 total)
  • #496336
    Con Nicoll 1
      @connicoll1
      Hi,
      Citric acid causes mild steel to corrode on removal of items from solution. it appears that this can be avoided by:-
      Total immersion for cleaning in solution. No part of item exposed to air.
      Immediately rinsing in clean soap and water on removal.
      questions:-
      Suppliers recommendation is 20gms/ltr solution. Is this the minimum necessary for 100% solution?
      Is 100% solution necessary to avoid corrosion of mild steel?
      This appears to work but I'd like confirmation that my assumptions are correct.
      Con Nicoll 1
        @connicoll1
        Corrosion of steel
