Circlip Pliers
Circlip Pliers
Home Forums General Questions Circlip Pliers
  • #90808
    The Merry Miller
      @themerrymiller
      Before I splash out on a decent set of circlip pliers I have a question.
      I have a very large internal circlip to remove from a motorised gearbox.
      The clip is about 2.5" dia and the two pin holes for removing the clip are about 0.1"dia on a pitch of 7/8".
      Would the pliers in a standard set be capable of removing a clip this size or would I have to go for one of the larger sets?
      Len. P.
      The Merry Miller
        @themerrymiller
        #90810
          @mike89748
          I was faced with a similar problem a few years ago and, as it was a one-off job, didn't want to splash out on circlip pliers. Bought the cheapest pair of long-nosed pliers I could find in a DIY shed, heat bent the tips and filed them to the right profile, then re-hardened them. Worked a treat!
          #90811
          Weldsol
            @weldsol
            You should be able to find wire forming pliers (the ones with round tapered jaws) these will probably do the job
            Paul
            #90817
            The Merry Miller
              @themerrymiller
              Mike,
              I've spent so much time in my life improvising tools that I thought I'd treat myself for a change as I'm now running out of time!!!
              Come to think of it I am continually treating myself according to her indoors.
              My grandson will no doubt feel happier no when he gets all of my proper tools eventually.
              I don't think youngsters will know how to improvise until they have got a bit of time and experience under their belts.
              Len. P.
              Edited By The Merry Miller on 14/05/2012 17:35:00
              #90818
              Sandy Morton
                @sandymorton10620
                I have a pair of circlip pliers which I purchased from CPC for £1.99 and they work fine up to almost an inch. I never needed larger ones but they might be worth a look.
                #90831
                Clive Hartland
                  @clivehartland94829
                  It is possible to buy a set of circlip pliers that do both internal and external clips and they come with a set of different size pins.
                  These can be bought from motor tool factors, as you can guess they would be invaluable to a motor mechanic and any other engineer needing circlip pliers.
                  I think I got mine from Sealey's.
                  #90838
                  The Merry Miller
                    @themerrymiller
                    I've gone for the Sealey set Clive.
                    Len.
                    #90839
                    The Merry Miller
                      @themerrymiller
                      Don't know how it managed to double post?
                      Len.
                      Edited By The Merry Miller on 14/05/2012 20:07:52
                      #90863
                      Springbok
                        @springbok
                        There are shedloads of both types going on fleabay for pennies.
                        #90880
                        Gordon W
                          @gordonw
                          On a clip that size I would use a small screwdriver or similar to start the key out of the groove and confirm that it is free. Usually can then "peel" the clip out without the pliers, should use a new clip anyway.
                          #90881
                          The Merry Miller
                            @themerrymiller
                            I tried to get it out that way Gordon, half successful due to very limited access and help from the missus!!
                            Len.
