Chuck backplate
Chuck backplate
Home Forums Workshop Tools and Tooling Chuck backplate
  • #17047
    Brian Wood
      @brianwood45127
      Brian Wood
        @brianwood45127
        Hello everyone,
        I have a backplate for threaded nose fitting removed from a 5 inch Pratt 4 jaw chuck and no idea what it used to fit.
        The thread is 1 5/16 inch by 11 TPI Whitworth form. It seems an odd size that I can't match so can anyone identify it please? The nose register diameter is also 1 5/16 inch.
        #115873
          Are you sure its not 1" BSP which is 1.309" very close to 1 5/16" and 11tpi
          Can't help with the lathe it went on but could it be someone was intending to use a pipe flange as a backplate and never got round to rethreading?
          #115874
          Brian Wood
            @brianwood45127
            Hello Jason,
            Thank you for that information, the sizes are too close to sort, so you may well be right..It has been machined tike a lathe backplate too and I never thought it was anything else when I fitted a Myford plate to the chuck in it's place.
            I can always bush it and remachine it for my use, but it might just suit someone as it is
            Regards Brian
