Hi Jack,
I have contacted Michlmayr’s as suggested by Bernard and I am in East Anglia with Norwich relatively close. So I am hoping that will work out. But their clockmaker isn’t back until after New Year.
Tommy Robson’s is the other side of the country, and Steve Fletchers company are also quite a distance from me so Frodshams might be the next alternative. But will wait to see what comes of Michlmayr’s first. However if I do need to look to London then South London would probably work out so here are some details.
The pictures were taken by the horologist who examined it: If you did find someone I am sure they would happily talk to them and give a professional description of what they found. I am not sure what they used to photograph it as the pictures are poor but that is all I have of the innards.
What they said is that several of the escape wheel teeth have been bent or damaged at ends and the circumference distorted. You can see it if you look at top of wheel in photo. They also said that the ‘Pivot is missing at top very possibly due to wear, not snapped. Bottom pivot also worn’.
After 150 years I suppose something is going to wear out.
Detent is ‘missing banking screw, missing locking stone’.
Marry Christmas
Peter
