Christmas has come early………
Home Forums Workshop Techniques Christmas has come early………
  • #98959
    Anonymous
      …but I must have been naughty as Santa didn't bring any presents. He just left all this swarf. Number one job this morning is to clear it up.frown
      Anonymous
        #98993
        NJH
          @njh
          Have you no shame? !
          N
          #98996
          KWIL
            @kwil
            You forgot to leave the carrots out for the Reindeer!
            #99048
            Anonymous
              Posted by NJH on 21/09/2012 17:05:42:
              In a word, no! And I got paid to make the mess. It's not as bad as it looks; the swarf is delrin, so easy to vacuum up. The vacuum only got blocked once, when it ingested a curl of steel swarf, which then traps the delrin. You'd have thought that what with Dyson being an engineer he'd had made sure his vacuum could cope with sensible tasks like cleaning up the workshop.
              Carrots? I should say not, did you see the mess they left? And the bench vice was just as bad. I used a wood saw to cut the 25mm thick delrin sheet into 200mm square blocks. It worked very well.
              #99057
              Chris Trice
                @christrice43267
                You should try turning urethane resin. Comes off in long thin ribbons at very high speed. I can put down a 2" layer over the workshop floor (well, everything) in no time.
