Posted by DC31k on 10/08/2019 11:05:23:
Seeing the picture, the carrier is the same principle as the Tormek drill sharpening attachment. The Tormek one is also worth looking at to see if it meets your needs. You can buy the attachment separately from the grinder.
The Tormek system looks well thought out too but its limited to four facet style grinds and is said to be slow. Appears to be best used with a woodworkers style wet wheel dipping into water. I'll bet it puts an awesome finish on the drill tho'. Around £200 I think which at first sight seems bit costly but if just works not too bad a deal assuming you have a suitable grinder.
I too had a Martex pistol drill driven device once. Fairly early one so they may have got better over the years. This was cheap, flimsy flexi plastic without proper shaft bearings. Worked, sort of, when it felt like it. I wasted some time trying to engineer repeatability in before launching into orbit (metaphorically speaking).
Sealey device looks good in principle but, when I had crawl over one, it seemed yet another "made too cheap" device. Drill holder and alignment devices seem on the flimsy side and you are totally reliant on the wheel holding its shape.
I've had far too many drill grinding device through my hands. Either personal purchases or "help a friend get it working" services. My experience has been that the inexpensive ones can be got to work for a while but you do have to be careful. For hobby guy who may sharpen 50 – 100 or so drills in a decade £50 (ish) and a bit of extra care may well be a good deal.
Trouble is the good, just works every time, breed are expensive. Tomek seems to set the starter price. If the market hadn't decreed that Ordinary Joe won't pay more than £50 (ish) even if "some frustration involved" there might be more market room for better devices given the usual mass production price drop. I can't see why the business end of the Kaindl i.e. drill carrier, post and slide couldn't be sold for under £100 as a bring your own grinder device.
Edited By Clive Foster on 10/08/2019 12:18:44
