Chop saw
Chop saw
  • #31430
    Sonic Escape
      @sonicescape38234
      Sonic Escape
        @sonicescape38234
        I'm building a chop saw for metal and I was thinking to share here the progress. It is going to use discs up to 350mm. I want to be very solid. I have this 3-phase motor for it:
        Today I started to make a large pin. It will hold together the base of the saw and the mobile part (motor + disc). So I'm making some kind of hinge. I have many 10mm thick 55x100mm metal plates that I'm going to use them for this. Bellow is a quick drawing.
        I wanted to turn the pin between centers. But I don't want to remove the chuck. So I cheated and I made a center and hold it in the chuck. As long as I don't remove it the concentricity should be perfect.
        My lathe is not aligned so I used a precision rod to measure the error. After adjusting the tailstock I reduced the error to <10 microns.
        I don't have a dog. So I welded a small piece of flat steel to one end of the bar. I'll remove it later.
        After cutting around 1mm in total I discovered to my surprise that the diameter of the bar is 0.2mm larger at the right end! So the tailstock is seriously misaligned. There was something wrong with my first attempt to aligned the centers. I moved the tailstock with 0.1mm closer to me. And after another 0.3mm cut the diameter difference at the ends dropped to 7 microns! So far so good.
        Edited By Sonic Escape on 17/06/2023 20:20:11
        #648888
        Jon Lawes
          @jonlawes51698
          I enjoy progress threads like this. When I can't get out to my workshop myself I machine vicariously through others! Thank you.
          #648895
          Nigel Graham 2
            @nigelgraham2
            Interesting project.
            That's a perfectly valid way that: a temporary centre turned in situ. Hemingway suggests that for using the boring-bars made as one of their kits.
            I'm not sure I'd have welded that lug on though. I'd be worried about distorting the bar. I have improvised dogs in the past by drilling and tapping the side of an old nut or slice of thick-walled tube to take a bolt that acts as both grip (with a surface-protecting pad) and driving-arm. For an application like yours I'd have welded the lug to the ring, and tapped through the extra thickness of steel for the grip screw.
            #648912
            not done it yet
              @notdoneityet
              The problem, with such welding, arises when you come to reversing the part between centres for further machining.
              Better, IMO, to fabricate a drive dog than mess around as you have done. A piece of flat bar, a bolt and nut as a drive and a pinch bolt (a slot cut to allow some pinch) or grub screw to affix the drive dog to the part being machined. Maybe spot drill the workpiece for the grub screw?
              What power is your motor for your chop ‘grinder’?  350mm discs will need a fair amount of power.  Also be aware of disc speed limitations – you will need different speeds for different diameter discs
              Edited By not done it yet on 18/06/2023 08:53:41
              #648995
              Sonic Escape
                @sonicescape38234
                Nigel Graham 2
                Distorting the bar by welding is not an issue because anyway I will turn it later. I also thought initially about a more elaborated method to make a dog. But welding produced a more rigid result. Even this "dog" was bend a little in the end.
                not done it yet
                True, but I don't have to reverse the part. I want only to decrease the diameter at both ends with a chisel style tool. The motor has 1.5kW S1. Up to 1.8kW @ 460V. I saw that some chop saws have motors up to 3kW. But I will give this one a try. I will use the VFD from the lathe, so I can adjust very easy the speed. The motor has 1400RPM. So with a 1:1 belt drive I should have the maximum speed recommended for carbide discs.
                Today I finished the work on the pin. I decrease the diameter by ~10mm at both ends. I made an interesting discovery. If I'm using oil, the cutting tool is rubbing the metal, accumulate tension and then suddenly starts to cut a large chunk of metal. You can see this at 0.42:
                On the other hand, without oil, the tool starts to cut as soon as it is touching the workpiece. It is also easier to maintain a constant cutting:
                I think I'll stop using oil. It also too dirty. I spend to much time cleaning the lathe. That brazed tool is very nice. I made it's edge very sharp on the grinder with a green stone and it didn't feel that is became dull after I finished cutting. It is also the cheapest tool I have.
                I also killed the dog because its job was done.
                Next I wanted to made the holes for the pin in the 10mm plates. I fixed the plate in the chuck like this. And turned it very slow, 70-80rpm maybe. I also avoided to stay too close to it.
                I discovered that I can't drill holes larger than 10mm. I need 1mm more to fit the boring tool inside to start to enlarge the hole. I should have a 12mm drill but I can't find it. I have also 16mm drill but I lost the ER32 collet for that size! And my giant MT3 drill is 2mm too large. Bad luck today. Time to do some shopping.
                Here is the proof that I need a chop saw. This cut was supposed to be made along the line, but I couldn't see it well because of the sparks …
                One last thing, this Milwaukee discs are cutting much faster that anything I tried before. It looks like a good brand.
                Edited By Sonic Escape on 18/06/2023 20:52:01
                #649008
                DiogenesII
                  @diogenesii
                  When you mount work in a 3-jaw like that, there's only one jaw 'driving' the workpiece round (the one at '5 o'clock' ).
                  If you use a single point tool to make an aggressive cut, say if cutting a rebate from the centre out, when that jaw gets to '10 o'clock', the cutting forces will be pushing it away from it's partner at '6 o'clock'', whilst the jaw on the short side will actually be trying to eject it.. ..you can see what could happen.. ..be careful..
                  Sometimes for work like that you can turn just one of the jaws in a 4-Jaw round to hold the 'long' end; maybe someone has a picture?
                  Edited By DiogenesII on 19/06/2023 07:37:56
                  Edited By DiogenesII on 19/06/2023 07:38:18
                  #649009
                  Hopper
                    @hopper
                    Or you can hold the plate in a similar way in the four jaw chuck and it will be more stable.
                    I think you would have been better off to turn the steps on the ends with a normal turning tool. What you are using in the videos is parting/grooving tool plunged straight in. Less than ideal and as you found, prone to erratic cutting. It is not really designed for that sort of use. But it got the job done so at the end of the day, that is all that matters.
                    Yes Milwaukee is a good brand for power tools and cutting discs etc as you have found. They are widely used here on construction site work which is notoriously rough duty. But not cheap!
                    #649027
                    Sonic Escape
                      @sonicescape38234
                      The workpiece feels very secured in the chuck and I'm using a low speed. Also I'm standing more on the right side than usually when working with this plates.
                      As for the aggressive cut, I'm going to use this arrangement. I would be happy if I could make a cut at all
                      There are adapters for this boring tools but I didn't figured out which type is required by my tool.
                      Here Milwaukee discs are in the same price range with Bosch and others. Around half a pound. What is really expensive is a Cubitron II from 3M. I wonder how that one is cutting because it is six times more expensive!
                      #649028
                      Sonic Escape
                        @sonicescape38234
                        Also I ordered this thing. I think it is called annular cuter. On the lathe I'll make only a 4-6mm hole to mark the right spot and then I'll move the plate on the press drill and cut a 22mm hole with that special drill. That will be large enough to insert the boring tool to make it larger.
                        Edited By Sonic Escape on 19/06/2023 16:18:15
                        #649363
                        Sonic Escape
                          @sonicescape38234
                          I finished boring a hole in the 10mm plate. Despite all my efforts I managed to make it some 0.18mm larger. I was making very fine cuts, I don't know how this happened. I think I need a telescopic gage. Now when I put the bar inside it has a small play and I don't like it.
                          So I consider to move to plan B. I think a taper will make the design less sensitive to exact dimensions.
                          #649540
                          Sonic Escape
                            @sonicescape38234
                            Today I made a tapered hole. By modifying the existing one. I choose 30°.
                            And I made a similar modification to the pin. Now as long as they are pressed one against the other they are fitting much better. There is no play.
                            I didn't turned the pin between ​​​​​​centers this time. I don't think it matters. I didn't wanted to weld again a piece of metal to turn the bar. Maybe is time to make a reusable dog.
                            #649611
                            Circlip
                              @circlip
                              Big motor and saw blade for flimsy construction.
                              Regards Ian.
                              #649612
                              Sonic Escape
                                @sonicescape38234
                                Posted by Circlip on 23/06/2023 11:13:41:
                                Regards Ian.
                                Hmm … what is flimsy?
                                #649723
                                Sonic Escape
                                  @sonicescape38234
                                  Today I finished the second plate. Also tapered. This annular cutter is very good. I used only 200rpm and light pressure but it is cutting very well.
                                  And this is the result. I will weld two flat plates to each plate that is supporting the pin. So I could use screws to connect them to the base of the saw. In this way I have a way to fix possible misalignments.
                                  #649729
                                  Nigel Graham 2
                                    @nigelgraham2
                                    A good step forwards having sorted the initial problem!
                                    #650091
                                    Sonic Escape
                                      @sonicescape38234
                                      I'm thinking how to make the arbor for the saw. It will have more or less the same length as the pin that I already made. It will be supported by two 35mm bearings. At one end the diameter will be reduced to 20mm for the disc. I want to use also 1" discs so I will made a sleeve.
                                      The motor has a 60mm poly-V type pulley. I don't want to replace it because I don't have a tool to remove it. I need a similar pulley for the arbor. But the only one I found so far costs more than 100 euro. So I want to make one. Is there a problem if I make it from HDPE? This would be my first choice for material. The second is aluminum.
                                      Today I bought 2 bearings. I choose a type that has a taper inside. I don't know how is called but I liked it more that the other ones where you have to use a hammer to put the bearing in place. That black nut is puling a slotted sleeve that is holding the arbor.
                                      It is also a self aligning model that it suppose to work up to 8000RPM. But at home when I opened the box I started to be a little suspicious. The balls are ringing and feel loose. I think it will be noisy. Also it looks like you could almost disassemble it if you pull the rings a little harder. I don't know it this is the best choice.
                                      Also I welded the horizontal support plates for the pin
                                      I found a picture with a chop saw that look similar in many ways with what I want to build. Mine will not be so ugly, of course smiley
                                      Edited By Sonic Escape on 26/06/2023 21:10:39
                                      Edited By Sonic Escape on 26/06/2023 21:12:28
                                      Edited By Sonic Escape on 26/06/2023 21:13:25
                                      #653290
                                      Sonic Escape
                                        @sonicescape38234
                                        Last days I made some progress on the chop saw arbor. First I made a poor man's dog. I need it to turn a 40mm bar.
                                        Then I cut the bar from 40mm to 35mm. This is the diameter of the pillow block bearings. I also cut one end to 1" diameter for the pulley. At the end of the video there is the everything assembled.
                                        I want to make a 10mm length thread on the arbor. M22x1.5. The thread will be used by a 10mm thick disc that will hold one side of the blade. I have a die and I made a simple die holder for it. By chance I found a short pipe with thick walls that was just the right size.
                                        I made a small cut on the wall and I inserted a piece of flat steel to lock the die.
                                        While welding I put between the die and the flat steel a piece of Aluminium from a Pepsi can. So I could remove the die later.
                                        I added also two handles and tomorrow I'll give it a try:
                                        #653328
                                        Ady1
                                          @ady1
                                          Put the metal plate into the vice jaws along the line of the cut
                                          and cut with the grinder disc skimming along on top of the vice jaws
                                          Voilla. A perfect straight cut every time
                                          Edited By Ady1 on 23/07/2023 10:17:44
                                          #653857
                                          Sonic Escape
                                            @sonicescape38234
                                            This Sunday I went to a bazar and I found an interesting tap holder. It was exactly what I needed. I made an MM22x1.5 thread on a 10mm thick steel disc. This disc will hold one side of the blade.
                                            The using the die holder that I just built I made a matching thread on the saw spindle.
                                            Everything went fine. But I didn't realized that the tap or die are not self aligning. Especially if the thread is not to long. So the result is this:
                                            The disc is not parallel with that spindle shoulder … so it is useless for keeping the blade straight. I think I will enlarge the hole in the disc to make it touch the shoulder. And then I will weld it. I would like avoid welding since it is a more permanent solution. But in this case I don't see other simple fix.
                                            #653861
                                            Sonic Escape
                                              @sonicescape38234
                                              Posted by Ady1 on 23/07/2023 10:06:57:
                                              Yes, I guess that should work. I found also another method. I make a light cut along the whole length. Just 0.5-1mm deep. This is easy to make it straight. Then the cutting disc will not slip outside of this line. Even if you can't see the line because of the sparks you can still feel it if you don't press to hard the grinder.
                                              #653865
                                              Nigel Graham 2
                                                @nigelgraham2
                                                Interesting progress.
                                                I've not seen a tap-wrench of that pattern before!
                                                Some tipse I hope you won't mind me passing on…..
                                                Threads for operational parts of machines, especially hefty great ones like that M22, are far better and more easily made by screw-cutting on the lathe. It will usually leave sharp thread crests unless you skim the bar down to a wee bit under size.
                                                Remove the bulk of the metal that way then use the die to trim the profile, rounding the crests to their proper shape.
                                                If the work allows I cut a short lead at root diameter on the end of the bar first to indicate having reached that (the dial or DRO should also tell you of course!). It also gives the thread end some protection in use.
                                                If cutting to a shoulder I carefully put a root-diameter groove there first, too, to give a clean run-out. Note that if the part is highly-stressed in operation it should have a tiny, smooth fillet radius, not a sharp corner..
                                                The disc is better tapped in the lathe – again even better screw-cut first. Use the tailstock to guide the tap: easier if it has a centre-hole in the end, otherwise put an oddment of rod in the tailstock chuck and drill a female centre into it from the chuck.
                                                Lacking a self-aligning tailstock tap-holder, my trick for a tap too big for the tailstock chuck to hold without slipping, is to use a tap-wrench but let the handle bear on a harmless area of the saddle. Rotate the lathe by hand for this, keeping the centre up to the tap. Use a suitable cutting-oil or paste.
                                                I also sometimes use a die-holder similarly, for smaller-sized threads, using the tailstock chuck against the back of the die or holder to keep it square to the work. Note – and this is something I picked up from this forum a while ago – when using a die straight off it is often best to turn the bar down a few thou under-size to give a properly circular surface and ease the load on the die. Stock materials are sometimes a bit over-diameter.
                                                Best practice is to turn complete, drill and thread then part the disc off; from stock bar. I find it always comes off with a hefty burr but careful work with a small file and the tap, and a final rub on wet-and-dry paper on a flat plate, clears that. This will give you a properly concentric part with the face perpendicular to the hole axis, and with any appropriate face groove or recess.
                                                If you do need hold a disc like that in a bench-vice, don't simply grip it as in your photo. That gives very little support, makes tapping it accurately very difficult, and worse, risks bending it. Instead, put an old Vee-block or piece of channel between it, even a Vee cut in a block of wood, and one jaw for better support. (A pipe-vice is of Vee-block form).
                                                I have an old 3-jaw chuck screwed to a big angle-bracket for holding in the vice, for such work. I did not make it but acquired it second-hand, and it took me a while to realise why its jaws had been bored to form internal steps.
