Choosing a suitable fine point capacitive phone stylus
Home Forums The Tea Room Choosing a suitable fine point capacitive phone stylus
  • #766506
    Greensands
      @greensands
      I am looking for a fine tipped stylus for use with capacitive sensitive touch phone but am having difficulties in finding one with a small enough front end to ensure the the accurate selection of characters. I have tried several types where the head end consists of hemispherical rubber pad having a diameter of typically 8mm but I find this too large in practice as it is all too easy to hit the wrong the character in use with the result that I end up with a garbled message. Can anyone suggest some possible sources of supply?
      Oldiron
        @oldiron
        #766518
          As a contented user of Apple’s Pencil … I had to think about this
          As an Engineer … There should be sufficient information on this page for you to make your own:
          https://www.stylusshop.com.au/blogs/news/how-does-a-capacitive-stylus-pen-work
          Greensands
            @greensands
            Yes but with respect, but isn’t that an example of what I have already tried i.e. a conventional ball point at one end and what looks to be a somewhat large diameter (8mm perhaps) capacitive rubber tip at the other?
            #766520
            John Haine
              @johnhaine32865
              I have a Pixel phone and Samsung tablet – I just tried the tablet’s fine stylus with the phone and it just doesn’t work so I think you may be out of luck unless your phone is specifically designed for stylus use.  Maybe use a different keypad layout, “landscape” format?
              #766531
              Weary
                @weary
                Maybe try & search ebay for +++++  Fine Point Stylus Pen  +++++ or some variation around that will get you started with suitable search terms and turns up loads of options?
                Item 204340016563, fer instance is the chargeable type and has a 1.45mm diam’ tip
                Note: I haven’t used any of these ‘universal’ fine point styli so cannot recommend any one in particular.
                Phil
