Hi there, all,
I have to make a tee-bolt to hold a rear tool-post on my ML7. It's going to be tweaked-up pretty tight. I had intended to use some 3/8" diameter free-cutting (EN1a??) rod that I have in stock.
Then I remembered that, many, many years ago, during one of the early factory attachment periods of my sandwich course, I was in the trainee model-shop and had graduated to use of their ML7s. On starting one job, I found that the thread on the tool-post stud had stripped (not me, guv, honest!!!) and sought advice from the person in charge.
He had a look and then said 'Follow me.' and led me to the tool-stores (NOT the raw material stores) and asked for 'the KE9'. At least, I think it was KE9 but it was 60-ish years ago! Anyway, it was some very tough stuff.
So, before I could proceed with the routine trainee tasks, I had to perform this extra-curricular job of machining a new tool-post stud. Cutting the thread was a challenge but my efforts met with approval.
Now, here's my question – shall I be wasting my time if I make my tee-bolt from EN1a? Should I look for some tougher (and hence more difficult to machine) grade?
Is this a situation where perfection is the enemy of good enough?
A supplementary question: I've always assumed that the 'KE9' description, or whatever it was, denoted a product from Kaiser Steel, was I right?
Best regards,
Swarf, Mostly!
