Ouch!
This morning I received my SPG milling machine – it’s the 2217-III – glad I did because I’m sure the price pressure will come in across all suppliers, they’re all sourcing from similar places outside of these shores and subject to exchange rate fluctuations, and of course rising prices of metals.
On the subject of table – I didn’t even look into the production options, as I’ll make my own. I did something similar for my lathe table (still need to wire up the old thing) – but I used a construction of mainly 30X30X3mm mild steel box section, and welded it. If you can weld, or know someone who could do it for you, it’s a good way to build, simply, a sturdy stand.
I tacked 1.6mm sheet to the outside, and made some 3mm plate doors for it too, so now it is a handy tool storage cupboard under the working surface.
I’ll do something similar with the mill, but I’ll put this on wheels. Then add some captive nuts to the base so I can jack the ‘cupboard’ off the wheels and level up accordingly.
David, if you have the money available to purchase a machine, I think I’d recommend you decide what you want soon and get on with it. The lead times won’t be going down and I suspect prices won’t be either. I’d have a look at SPG too, you’ll be able to guess what machines they have when you see the picture, so far I’m impressed (pre-chip-making impression)
