Just to add to the debate – Under the latest UK house wiring regs, all screw type junction boxes etc have to be easily accessible. Some Wago connectors (other makes are available) are classed as maintenance free and can be used where they are not ultimately accessible, such as under floorboards etc. I think this is a good endorsement of their reliability.
I have used them and they are great when working in confined spaces, Time will tell but I have come across a lot of doggy screw connector joints and will even admit to being responsible for one or two myself (in poorly designed connectors of course!).
Screw terminal junction boxes and Choc bocks, Lego brick connectors, barrier strips, call them what you will are the last choice for me now. I even prefer crimps in some circumstances, provided the right crimp and a good ratchet type crimp tool are used.
Going back to choc blocks and in particular, stranded conductors, there is always the problem of stray wires and there is a temptation to tin the bare wire with solder. This cures one problem but unfortunately, causes another in that it creates a weak point and I have seen several fractures of the wire at the junction of the tinned wire and the insulation. Crimp "bootlace" ferrules overcome this.
If using connector blocks, I would not use ready made jumpers unless it is a 'production run', I'd save money and make them from solid copper wire.
Hope that helps.
