Posted by JasonB on 24/06/2013 19:51:36:
I've not really had any inserts chip from intermittent cuts be it on the lathe or mill, usually only if you knock them or wind the tool into the stationary work.
That mirrors my experience; I've never chipped an insert during actual cutting.
As an example the tapers on the conrods for my two traction engines were turned on the lathe using one 5mm carbide button insert for both:
I started with the roughed out shape at the top, and finished with the one at the bottom. The interrupted cuts were done at 800rpm and 8 thou/rev feedrate, so no pussyfooting around. The speed was increased, and feed decreased, for the finishing cuts.
In general for carbide run it hard and fast; it's happy running hot, so you might as well do so. For milling, avoid step overs around 50% to reduce shock loading as the inserts enter the cut. Less, or more, is fine, but not in the middle.
