Chipmaster developed a knocking noise
Home Forums General Questions Chipmaster developed a knocking noise
  • #678349
    Milly S
      @millys
      Hi all glad to be back
      my Chipmaster has developed a knocking noise,took back plate off headstock checked shaft/bearings/oil drip tube & anything else I could see all seemed ok
      took front gear box cover off checked gears cogs shafts & bearings all seemed ok no play no nasty loose bits of metal
      took belts off to check motor all ok
      don’t know what to look for next
      any help appreciated
      cheers
      steve
      Chris Crew
        @chriscrew66644
        Without hearing the noise for ourselves it is very difficult to know what to suggest. Can you locate the knocking to a particular part of the lathe? Does it occur at all speeds when different gears may be engaged? Perhaps one of those old-fashioned listening devices, sort of a door-knob on the end of a metal rod, may help. They used to use them for detecting knocks in car engines, they may still do but I gave up working on anything to do with cars when they became a computer on wheels.
        #678698
          A broken shear pin confused me once because it intermittently slipped on the burr.  Everything looked OK!
          I’ve used a big screw-driver and lengths of wood as a stethoscope as described by Chris.  Helps considerably to zero in on where the clonk is coming from – loudest.  Like many old-fashioned ideas, it works, but not particularly well.   These days proper doctor style stethoscopes can be had quite cheaply – worth buying one.
          Also is there a pattern?  Such as only occurring when the gearbox is engaged, or when cutting etc.  Try to narrow it down, for example does it clonk when the motor is run with the belt off?  Does it clonk when the spindle is turned by hand and everything else is disconnected.  Check the shaft keys in case one has worked loose etc.
          Some people enjoy fault finding, I hate it!
          Clive Brown 1
            @clivebrown1
            Complete thread drift but, not long ago, a water board man came along our road with a nicely made wooden pole about 4ft long. He used it to listen for possible leaks in the water main under the pavement. Real hi-tec!
            #679344
            Milly S
              @millys
              Hi all
              tried the big screwdriver & a long metal bar tight on ear it’s hard to detect as it’s intermittent when it goes it sounds like a knock on metal by a light hammer it stops for a while then starts again this happens at any speed also worse in reverse can’t hear it if you crank by hand
              thanks
              steve
              #679467
              DC31k
                @dc31k
                Is there a way to bypass the variator and turn the spindle under power? That would eliminate it as a possible source of the noise.
                #680071
                petro1head
                  @petro1head
                  May be an idea to video the noise
                  #682282
                  Clive Steer
                    @clivesteer55943
                    I have had a cyclic knocking noise on my chipmaster since I first got it some 20 years ago. However the noise is only audible when I’m using the parting off tool. It appears to emanate from the headstock but since the Chipmaster spindle is direct drive it can’t be attributed to gears. I have removed the variation from my machine so my motor drives the headstock through the matrix clutch which could be the cause. Speed control is by a 7kW VFD but only because I had one. This has, for my type of work, been fine with good performance and quiet operation.
                    I haven’t investigated further as the noise hasn’t got worse over time or affects the function of the machine.
                    However my machine has had a fairly hard life in the past so it may be the result of some earlier abuse.
                    CS
                    #682648
                    Milly S
                      @millys
                      Hi Clive thanks for reply I’ve tried just about everything possible to try and resolve problem with lathe
                      I asked the company I bought it from to take a look at it which they did unfortunately they could not sort problem
                      it’s a shame as I would like to hold on to this lathe but not if problem can’t be put right so I’m afraid I’ll be returning it
                      i would just like to thank everyone who has contributed to try & resolve this problem
                      best regards
                      Steve
                      #688216
                      Alan Jackson
                        @alanjackson47790
                        Testing if the system works after writing a long description and it disappeared on posting
                        Alan
                        #688217
                        Alan Jackson
                          @alanjackson47790
                          I have just written a long description of how I tightened the end nut on the spindle fully tight for the knocking noise at the spindle when turning by hand has now stopped. However my long descrition disappeared whe I tried to post it. Good luck Clive This might work for you.
                          Alan
