Ian,think you may be right in that although difficult to see the face between the end cap and the disc there may be a ring of friction material around the circumference of the disc to give friction between the disc and end cap.
I had assumed the gearbox which gives a large speed reduction would in effect give enough braking due to the high gear reduction. I can't really investigate the disc further without extracting the windings whch I am loathe to do. Maybe some grease on the splines (avoiding the friction ring) would assist magnetic force in attracting the disc away from the end cap.
Will have another play tomorrow and if necessary will extract the winding to get a good look at the disc ,even if this is destructive (if I can't fix it I will be less loathe to risk destruction ) as knowledge gained this way might be useful if I ever have to repair another. Will report back.
Generally speaking I have been pleasantly surprised with how well made the motor appears altho its also true it has stopped working.
Chinese products seem to go pretty well for me with the exception of the highly stressed items such as angle grinders. compressors, SDS drills and now, hoists. Unfortunately practically all the reasonably priced of these items , indeed practically all available, appear to be Chinese made. These items for me are very occasional use items and I usually shy away from digging up one of my small bags of gold to pay two or thee hundred pounds for an occasional use item.
With machine tools where stresses are highest I tend to stick to older European or British machines but with the general handyman's workshop items there is n't much choice. A possible exception is Costco who tend to import a lot of more reasonably priced U.S products but one does n't get the choice of several product ranges there.
Rgds.
Edited By alan frost on 28/04/2012 23:36:09
