Warco do a gear head with hardened and ground gears – that's what is needed for low noise levels. I've never heard one running but have used a number of colchesters, dsg;s, holbrooks, langs and others where the noise levels from the gearbox is very low. The motor can easily makes more noise under load. These were all in pristine condition. They get louder with wear. I've no idea how well the warco lathe gears are ground but it might be costly to match the main makers so there is a need to be realistic.
Being weird I am currently looking for a small true metric lathe. I visited a used Axmister BV20M a couple of days ago. Gear head and I suspect a slightly stretched version of what was the well regarded 918. I found it interesting compared with similar machines now. It seems to be very well made and rather heavy as a result. Only light use and one owner. Noise levels ruled it out for me but it wasn't that bad. Bigger than needed too. Similar noise levels to the small millers that were sold with a speed reduction gear but "more continuous".
I'm only a few yards from the living room so have to be careful on that point. There was a belt drive version of this about as well.
Now we get a combination of casting kits and electronic speed control without enough pulley settings to give either a good speed range or sufficient torque reading through the lines. 2,500rpm to make sure the bearing wear out quickly if that sort of speed is used much especially with 3 morse spindle. Looking around has left me feeling a bit jaundiced about the whole area especially at the small end.
One interesting aspect of the sort of lathe mentioned is that it seems that they can easily be bought in 0z and can be bought in the USA and they aren't that expensive either. Reports on them when they can be found seem pretty good really considering the cost. But the weigh a lot more and also take up more room in a container. It also seems to me that profit percentages grow markedly in the UK as what might be called usability increases. On the other hand I have seen adds for machines where the seller points out that the details are a guide only and the actual product might vary when it's supplied. Wonderful business model. Might be good for them but not for buyers.
Rant over. I'm a bit hissed off on this subject.
