Hello,
I'm building the Jenny Wren combined engine and boiler in Stan Brays book "building simple model steam engines". My third engine. A picture of the front cover of the book is here and the picture could be a schematic for the Jenny Wren.
Both the curved pipe and the chimney in this model are in contact with steam. The chimney (Brass) rises up the centre of the boiler tube and provides an internal wall concentric with the outer wall of the boiler. The curved pipe (Copper) takes steam from the boiler to the engine. The boiler body can be either brass or copper.
Some Jenny Wrens made by other folk are here
What is the logic behind using brass or copper for different parts of a boiler or steam engine please – are there any instances where one is better than the other ? It seems permissible to allow live steam to make contact with either material. Fittings / connections / safety valves / are generally brass rather than copper ? Copper is a bit soft and sticky to cut ?
Any books or websites I should be reading to better understand material selection ? I've got the Stan Bray and Tubal Cain "Simple Model Steam Engines" books already.
Thanks
Bill
