hi Bob,
there is a problem with the original Speedy draughting.
i have re-done it using Jos Koopmans' formula, and if you PM me will gladly send you the details.
for machining the chimney, do the inside to the corrected dimensions, then fit on a mandrel to suit to do top and middle and part of the base. the rest of the base is best done with a sharp half round file putting the mandrel plus chimney in the bench vice.
note that for a GWR copper capped chimney gunmetal is the wrong colour, and you may like to consider a separate copper cap or hard drawn bronze copper cap.
cheers,
julian
Edited By julian atkins on 24/12/2015 23:03:56
