Hi All,
I have a Chester Super Lux that I am attempting to 'make good'.
If anyone has a similar mill – RF 45 clone type that has an R8 Spindle would you mind measuring the wall thickness of the spindle at the nose please?
Also, how far does the nose protrude from the lower cap?
Mine is a Morse Taper 3 but having to tap out tooling all the time is something I'm really not comfortable as each hammer tap is driving straight through the bearings which will be new.
I am considering regrinding it to R8 but this will only leave a minimum wall thickness of just about 5mm right at the nose (and that is starting the taper right at the nose so including the key slots) and again at the narrowing for the lower bearing seat with the rest obviously having more meat.
These mills all seem to be supplied now with an R8 spindle as standard but still seem to use the same bearings but other than Grizzly in the States that want lots and lots of penny's for one I can not find one anywhere else for love nor money.
Unless anyone knows where one might be purchased?
If not an option I saw someone suggested the modified drawbar route that could be an option.
Hope all are well..!
Cheers
