Chester DB7 Lathe Motor issues
Home Forums Manual machine tools Chester DB7 Lathe Motor issues
  • #751118
    trexcarey
      @trexcarey
      Guys and Gails, I have an issue with the drive on my small DB7 lathe. When I haven’t used it for a while, the motor on startup is very slow and then builds up to the speed it is set at on the VFD. Plus, it doesn’t seem to have the power it used to and stalls on some of the lightest cuts. Does anyone have a suggestion as to whether this is likely to be the motor or the VFD drive electronics?
      Thanks
      Andy
      bernard towers
        @bernardtowers37738
        Before you dig in to the electronics check all the mechanicals for free running. And run the motor with the belt/drive off.
        #751157
        trexcarey
          @trexcarey
          Yes the whole system all runs free
          #751194
          Brian Wood
            @brianwood45127
            Hello Andy,
            I don’t know the lathe model but it sounds to me to be the result of dry bearings that are loading the motor, added to which you say its performance once running is now feeble. It is clearly struggling.
            Try an extended run with belt off to see of the motor gets hot or noisy and act accordingly.
            #751213
            bernard towers
              @bernardtowers37738
              If its a brush motor try the brushes
              #751221
              Les Jones 1
                @lesjones1
                Can you confirm that  the version of DB7 does use a 3 phase motor and a VFD ? The only versions with variable speed I have seen have used a DC motor and speed controller.
                Les.
                #751517
                trexcarey
                  @trexcarey
                  Sorry yes VFD was the wrong terminology it is a DC motor by the looks of it. I think I will drag the motor out and see if there are any serviceable bits and check the bearings as the bearings on the lathe seem fine.
                  #751535
                  Les Jones 1
                    @lesjones1
                    The only servicable parts on the motor will be the bearings and the brushes.  If you connect a mains voltage 100 watt filament lamp in place of the motor it’s  brightness should increase as the speed control is increased. If this happens the speed controller board is probably OK.
                    Les.
                    #752185
                    trexcarey
                      @trexcarey
                      Hi Les,
                      Thanks for that. I have been away all weekend and will try this next week.
                      Andy
                      #752200
                      Hugh Stewart-Smith 1
                        @hughstewart-smith1
                        hello Andy,
                        If you are still having the same problem then you’re welcome to contact us at Amadeal as we can send you a test chart which may be of help to diagnose the problem.
                        Hugh        Amadeal Ltd
                        #752300
                        mark costello 1
                          @markcostello1
                          WOW, excellent  service.
